Electrically, this car feels like Herbie(goes bananas)
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Finally got the brake lights working perfectly, for 2 days, and now I am back to the heated rear window not working and when I engage the brake pedal the HRW switch lights up i front of me! Brake lights still seem to be working though, so that is still, technically, an improvement. Basically, I replaced all rear bulbs and the brake lights worked from there. But this HRW thing is a problem now. As far as I am aware, the switches for Brake lights and HRW are both fitted above the brake pedal. I am thinking of unplugging both, spraying any terminals with carb cleaner and re-fitting. Failing that, it could be an earth on the back of the car, but I doubt that. The car had this problem when I took it home. Once I replaced the rear light bulbs the problem ceased. Now it's back again!
To make matters worse, the cigarette lighter isn't working. I don't need it to smoke, but because the CD changer is no longer in the car, I was hoping to hook my MP3 player up to the ciggie lighter, and I found that it doesn't work. I removed the lighter unit and all wires seem fine and plugs too, so I have no idea where to look to fix that one now. I tried the tape adapter idea to my MP3 player but that doesn't work either. Just gives a big humming noise!
I am still down 1 reverse light but haven't had an opportunity to test with a multimeter yet. I have inspected the wiring and plugs in the boot and they all look in really good condition. I'd rather not have to splice open the wiring. Could I just send a new wire across from one reverse light joint to the other and seal it with insulation tape or something?
