Just had a closer look at the earth cables in the boot of the car. Took some pictures. Left and right earth both look solid, although there are 2 brown cables on the left(passenger side) and only one on the right. I took some other pictures too. The wiring into the brake lights and indicators, which all looks ok.
About the reverse lights, I didn't notice any earthing from them. There is brown cable going into the bulbs, but doesn't seem to be any fixing to the car. And there is a nut placed exactly between the two lights, in the middle of the boot door. Should there be an earth cable to this from one of the reverse lights?
Finally there is a loose plug on the left had side(passenger side). My guess is that it used to be the cd changer, which is no longer in the car. Could this unbalance the electrics since it is going nowhere now?
Pictures:
Passenger side, in the boot, 2 earth cables. Seem solid. Not electrically tested yet as I can't find my tester.
Driver side in the boot. 1 Earth cable. Again, seems solid, but why only 1 on this side compared to 2 on the passenger side?
Passenger side wiring into the brake light/rear indicator.
Driver side brake light/indicator wiring.
Finally, a nut in the boot door, position right in the middle, between the 2 reverse lights. Doesn't seem to be doig anything. Should this be earthed from the reverse lights, and if so, how should I proceed?
Does any of this show anything that might suggest what I need to do?
Thanks.
