Electronics novice but I have managed to wire in a 12v vanity LED light circuit in my bathroom. It is from a 12v 15W (Max) driver which is housed inside a boxed in cabinet space. The light circuit uses a standard wall switch.
I've just had to replace a humidity activated extractor fan which was mounted on the same cabinet with one that is switch controlled with a timer function. The new fan is 240v 14W and has its own isolator switch (again, inside the cabinet) and supply.
Q: Can I use the 12v switch to activate the fan? It is very conveniently placed and i'd rather avoid more switch installations if possible.
