- Joined
- 27 Jan 2008
- Messages
- 25,314
- Reaction score
- 2,959
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
15 amp sockets do have shutters, and since no fuse do not get hot like 13 amp plugs, however it would need two cables one for each socket as it will need a 16A MCB/RCBO on the feed to each socket, so no advantage using a 15A socket to hard wiring other than removal for maintenance.
In real terms using a 32A supply for oven, hob, or cooker is standard practice and no real problem, only when using a 45A supply is there a question as to if you can supply an item designed for 15A with such a large supply.
