Who knows? It's difficult for a standard to impose requirements in relation to performance after long periods in service under unknown conditions.It seems much more common now, than I think it used to be. I think standards in manufacturing of both sockets and plugs have declined - they might meet spec., but do they meet spec. long term?
Up to a point but, over the years, I have on a few occasions come across instances of a 3A or 6A fuse blow when (inappropriately) put into a plug supplying a 2kW or 3kW load.I think the 13amp fuse only helps by blowing when there is a short, rather than a bit of overload, even then - more often than not in the case of a short, it's the MCB which trips rather than the 13amp fuse.
In any event, this doesn't alter my belief that, since a 13A fuse may allow ~22A to flow for long periods, the Standard should require the plug/socket to be able to cope with that (at least initially) -which is not the case with BS1363.
Kind Regards, John
