3phase problem
The legacy of PCBs is that before we can do work on any oil filled equipment (90% of at 11kV) it must be tested for the presence of them!
If they are found (and they can be) we cannot drain them down to mix with our stocks (obviously) or to go for recycling.
Transporting the equipment from site is an expensive nightmare as well owing to Environment agency rules.
One of the biggest sources can be power faction correction capacators
Thank you guy's for all the advice.
It was the dashpots being low on oil. I unscrewed them, filled with 3 in 1, pressed start and off she went.
We still have to replace the single phase 3 core flex for 4 core 3 phase, but it works, so thanks.
Steve.
Glad to hear of the happy outcome. However, I wonder if, like me, you are starting 'to wonder' about...
I have just had delivered a professionally restored woodworking machine.
Kind Regards, John
Im more intriqued the electrician charged £40 didnt try that and opted for 150 pound to change the starter.
On a busy site that could have cost a days production.
If in doubt I would have at least phoned a freind.
Anyway happy its going and moreso for letting us know
If in doubt I would have at least phoned a friend
Or start a thread and ask on DIYNOT :)
How many present day "electricians" have ever seen one of those?
I see where your coming from but 333rocky333 is right as my electrician did mention that possibly the dash pots were dry, but thought safer to go with a new starter anyway.
I wonder, as they didn't bother to check the dashpots, what else they've ignored/forgotten. Nice coat of green paint though.
Have you checked the earth bonding to the body of the machine?
I wonder, as they didn't bother to check the dashpots, what else they've ignored/forgotten. Nice coat of green paint though. Have you checked the earth bonding to the body of the machine?
Indeed, not to mention the use of brown-blue-G/Y flex for the three phases, which doesn't really engender confidence!
Kind Regards, John
That could have been intended as a temporary measure, just to check the electrics, but a professional machine restoration company should really be familiar with older-style starters, and shouldn't be selling machines that they haven't checked properly.
That could have been intended as a temporary measure, just to check the electrics ...
I'm not sure I understand that statement - in what sense could it be regarded as 'a temporary measure' if this "professional machine restoration company" sold it to a customer in that state?
Sure - I obviously agree with that, too.
Kind Regards, John
It's appallingly incompetent, I was just speculating on what might have led them to do that, and the only marginally justifiable reason I can imagine to use single-phase flex was to check if the electrics worked, with the intention of correcting it before selling on the machine.
The more I think about it, the less I would be inclined to use that machine until it had an IR test and an earth continuity test by someone more competent than the machine refurbisher.
Why do i get the feeling that this "restorer" is a guy who does it as a sort of hobby in his garage/workshop at home?
I've met a number of companies who refurbish old machines, and without exception they have been incompetent, unsafe, and criminally negligent. They seem to think that as long as they give a machine a nice shiny coat of paint and clean the rust off the bare metal parts, they've done all that is required.
