I have quite a long run of 6mm twin & earth that I need to work out the max current capacity for.
From CU its 7mtr clipped on open tray with other cables, then 3mtr in 40x40 plastic trunking (space factor observed) then 3mtr clipped direct to joists, the last 3mtr is under capping at plaster depth.
I would like the circuit to manage a max current of 32amps but my feeling is it may fall short in 6mm.
What do you make the max current capacity pls?
