6mm2 twin and earth for EV charger
17 Oct 2008
Kent
Hello
Had induction hob removed, cable left 6mm2 routed via void between ground and first (no insulation), across house, then final 2m down side of internal solid wall clipped to wall, with 45mm celotex in front. (Then taken out the wall)
Nothing else using cable of course.
Have electrician coming and wanted to avoid relaying new cable, so use this with zappi at end, and new mini CU box for this item only by consumer unit , Henley block.
I tried the tlc direct voltage dropper thing and the cable run of 18m, it says all good, bit no harm asking everyone here. :)
I think you need feedback from the spark coming to take a look.
Eyes on-site trumps random internet advice
