Correct outdoor cable management for EV Charger?
Condinsation can build up when conduit used. So you probably need a drain hole in the bottom of the isolator. And zappi
You could have used ev ultra cable. SWA. power and data in the same cable
Thanks for the advice folks. The electrician called around and we finished the job. Entry of the power into the isolator was moved from the top to the bottom to help weatherproof it. He thought it was overkill to swap the conduit & twin & earth for SWA, but since I had the cable bought and holes made we did the change. We made a drainage hole on the underside of the conduit loop for the ethernet for condensation alright.
Interestingly enough, his issue with the RCBO was the brand, Garo: he said that they were know to trip with the Zappi, and was advised to swap them for Hager to resolve them. He said to monitor the Garo that I had for that.
