- Joined
- 27 Jan 2008
- Messages
- 25,741
- Reaction score
- 3,051
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I would look at the lack of clips on the EV twin and earth as a sign as to how installed, also the lack of any supply not going through a dedicated RCD, since the new unit has a built-in RCD the question is should one use cable not requiring RCD protection for the whole route?
Not really talking about rules and regulations, but swapping an EV charge point using a cable which seems to have been just thrown in, with no warrantee of skill.
It may be within the rules and regulations, my edition of BS 7671 is well out of date, but my first job would be removing the lid from the consumer unit and see if it has three neutral bars, need to work out how one can get a supply where the RCD is not shared with other equipment, and once I know the options, then look at the price.
RCBO's cost more than MCB's, and the price varies make to make, so need to price the different options, I remember doing this for one job, and a complete new consumer unit worked out cheaper than upgrading the original. And the big difference was the price of the SPD, and these have since become cheaper with many makes of CU.
Personally, I prefer all RCBO protection, as it means should DC freeze a RCBO it is only affecting one circuit, we talk about less than 10 mA DC which is nothing, even for the B type RCD, and more and more in the home is using equipment which can generate DC, so what I want, is for my washing machine even if faulty not to affect my lights.
If you want to change to gain so little, then to use SWA all the way seems a good idea.
