Fair enough - it's what you like/want (and are happy with) that matters.The knife block stays there not moved - same for the kettle it sits on its base but does get picked up to uses I suppose but the plug is totally visible.
Kind Regards, John
Thanks for the suggestionWhy not fit a cable management device to the worktop that allows the moulded plugs to be passed through? As used on millions of office and shop desktops/counters.
They may even look OK, and will be more practical for maintenance purposes.
One example in "brushed steel": https://www.amazon.co.uk/METAL-OUTLET-GROMMET-INSERT-Brushed/dp/B00DUW2C1A
Following on from this thread I came across this
Redirect Notice
www.google.com
quite apart from it looking hideous, surely the fact that pan head screws have been used to fix the faceplate down will also mean that the plug won't sit flush.
Still what can you expect for £70 this days
Quite so - and, unless it's 'a trick of the camera', it looks as if those panhead screws look to be brass (or maybe gold, given the pricequite apart from it looking hideous, surely the fact that pan head screws have been used to fix the faceplate down will also mean that the plug won't sit flush.
Maybe there's a surcharge for the hideousness?..... Still what can you expect for £70 this days
You could place a switch above the bench top to control the socket-outlet underneath the bench topYes there is. I saw a post about this where someone was asking if it was ok what their fitter had done and he had loose sockets under in surface mount boxes, which was a whole other debate about allowed or not.
The other thing is if we ar going away for a few days we like to turn them off at the socket.
If you start with a white plastic product you can use Vinyl Dye to dye it almost any colour that you like.Cant I just have a nice plug
why can i not find a grey one, white, black, red but not grey.
Now that is very interesting, have you tried it yourselfIf you start with a white plastic product you can use Vinyl Dye to dye it almost any colour that you like.
You can also dye your wall-plates etc. to match your decor. (Don't attempt to do this "in-situ".)
See https://www.vinyldye.co.uk/
and https://www.vinyldye.co.uk/Games_Consoles_Vinyl_Dye
One caveat, has the manufacturer of that colour actually declared its non-conducting properties for safe use on plugs, sockets etc ?Now that is very interesting, have you tried it yourself
A similar product but only on "cordage".Now that is very interesting, have you tried it yourself
That does not matter if one colours only the "rear" and leaves the electrical contact side "as - is".One caveat, has the manufacturer of that colour actually declared its non-conducting properties for safe use on plugs, sockets etc ?
