- Joined
- 27 Jan 2008
- Messages
- 25,373
- Reaction score
- 2,984
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
This sort of problem is not only with houses. I was told to remove un-used wiring in a concrete factory. The old electrician came and identified the un-used wiring and of course I also tested all cables with a test lamp including using a proving unit. And they were all dead. With a concrete factory in some areas all one could do was to saw through the cables as firmly concreted in. One junction box without lid was also to be removed and from the state one would assume it had not been live for years.
So all going well until I returned from tea break lucky. At which point I am told cable sparking and the auger was not working. Seems it was just one item from old plant which had been retained. Cable joint and alls well. However once this near miss had happened it was decided that cables would only be removed when plant was not is use.
But it is all too easy to make mistakes with old cables.
As to PIR with un-identified circuit I would disconnect the cables and insulate in consumer unit ready to re-connect if it was found latter something didn't work. But PIR's done on a budget likely this could be missed.
We are all told we should drop the tails and switching of a MCB and using tape over lever is not enough. However it is some times not possible to isolate else where so one way or the other one has to break the rules. be that pull the DNO fuse, work on a board live, or just put tape on the MCB one has to break the rules. I do have locking clamps but not for all makes of MCB and they will not fit some consumer units. And one is hardly going to leave a locking clamp on a MCB as a permanent isolation.
Yes DNO should provide an isolator but often they don't so we break the rules.
In the past I have also used tape inside a locked cover so in theroy only another electrician could turn it back on. However again a near miss when a mechanic had wangled a key off some one and turned the power back on taught me in my early days to drop tails.
So yes likely a PIR would have missed the problem. However it would have raised the point about buried cables and RCD protection and maybe the new owner would have had the consumer unit changed to one with all outputs protected by RCD.
And that is really the point. No matter how careful one is accidents will happen. So using RCD's is really the only way to protect from this type of accident.
Having said that I sawed through a lighting cable going horizontal across the wall while fitting a water supply to fridge. In spite of all RCD protection it still knocked me out for few minutes. As to if I let go of the twin hack saw blades being used to cut the channel I don't know. But I could not really blame the electrician who ran the wires horizontally between a pair of two way switches as it is permitted. It was my fault for not using a cable locator first. I did test RCD and yes it did trip before 30ma and within 40ms but still got one hell of a belt.
Worst bit was my pride. How had I an electrician made such a silly mistake. But it happens and I can see reason for 50mm rule.
