Looks like red-yellow-orange to me, that would make it 27k.
Red = 2
Yellow = 4
Orange = ,000
7 would be Grey...
7 would be Grey...
Yes, I think that's right, but virtually only with TN-S supplies. With a TN-C-S supply, the supply-side fault path is identical in the two cases, so that anything affecting PEFR will similarly affect PSCC, and vice versa. AFAICS, only a faulty neutral connection between cutout and DB/CU could result in PEFR>PSCC (as measured at DB) in a TN-C-S system.Afaict phase-neutral fault current will usually be higher than phase-earth fault current because earth wiring is usually higher resistance than neutral wiring but there are a couple of scenarios where PEFC could be higher.
1: A bad neutral connection.
2: An installation with significant parallel earth paths (supplementary bonded structural steelwork, conduit/trunking systems, systems where several submains run paralell to each other and have their earths linked at the far end) .
And to me!Looks like red-yellow-orange to me,...
Yellow = 7? Try again!... that would make it 27k.
As I said last night, I think the end band is either silver (10%) or nothing (solder plus ageing). Otherwise, well doneHmm, more tricky.
24K 5% If that end band is gold. I think...
Not sure on this one. I don't know what the rules on direction of reading and meaning of bands are for color coded capacitors (i've only ever seen a handful of such caps anyway)... and, of course, the 'resistor colour code' is not only used for resistors - capacitors (and sometimes other components) also sometimes use it. Any takers for:
That will be 100000 pF or 100 nF
Start at the top and look at just the first three bands. Without looking it up, I can't remember how to decipher the 4th and 5th bands, but they don't relate to the value of the capacitance.Not sure on this one. I don't know what the rules on direction of reading and meaning of bands are for color coded capacitors (i've only ever seen a handful of such caps anyway)
Indeed, or even 0.1 μFThat will be 100000 pF or 100 nF
... and a good few other components these days. I suppose some may be just too small to mark.What really gets me though is that surface mount capacitors don't seem to be coded AT ALL.
Doh, doh, doh.And to me!Looks like red-yellow-orange to me,...
It happens to all of us! I suspect one of the issues here is that your subconscious (which has some control over your typing fingers) is pronbably most familiar with the E12 resistor series - which, of course, includes 27k, but not 24k!Doh, doh, doh. Does anyone else have a problem where they think one thing and the fingers type something else ? Yes, Yellow is 4 and 7 is violet. And I can't even use the excuse of hitting the wrong key as I wasn't using a numeric pad when I typed 27k.Yellow = 7? Try again!
Does it work for liquorice allsorts?... and, of course, the 'resistor colour code' is not only used for resistors - capacitors (and sometimes other components)
Probably!Does it work for liquorice allsorts?
