You're rambling ... What point are you trying to make other than we will probably consider what you are posting as nonsense?
Again with the paradox. This is completely correct. Nobody is arguing about that.JohnD said:It is impossible, at the same time, for the plane to be moving, and the conveyor to match the speed of the wheels.
The forward speed of the plane must be equal to the forward speed of the wheels minus the backward speed of the conveyor.
The rules in the question cannot be met unless the plane is stationary.
Nobody who understands the principles of Newtonian physics would find it to be anything other than [mostly] correct. The idea of the wall actually moving is, however, incorrect.blondini said:Every action has an equal and opposite reaction. e.g. You push against a soild wall and it pushes back with equal force. The wall behaves as if it is tuned to match the force you apply. Although the wall doesn't appear to move, it must do so in order to react. The runway surface is pushing upwards to support the aircraft and it is also pushing back against the lateral force trying to move the aircraft. Even before the aircraft begins to move, it is applying a lateral force to the runway and the runway is pushing back. Most people would consider all of this paragraph to be nonsense.
This is leading nowhere, because the people who might need to allow such a thing as "give" are the very same ones who aren't capable of understanding your point.A tyre rolling along a surface will experience a minute amount of slippage in the direction it is travelling. If the tyre is being pushed by the vehicle it will rotate slightly slower than the speed of the vehicle. If it were propelling the vehicle it would travel slightly faster. There is a bit of give here, although again, most people would consider this to be nonsense.
That's cool. I'm just hoofing a couple of them back towards you. Jumpers for goalposts, etc.blondini said:I'm just kicking some ideas around Softus.
That seems completely correct to me.blondini said:Thinking about this one a little further. The opposing lateral force of the runway, static or stationary conveyor, is applied to the plane only through the rolling resistance of the wheels. With only a small force from the engines, the plane will not move. As the force applied by the engines increases it will reach a point where it exceeds the rolling resistance of the wheels and at this point the wheels would start to turn.
I think so too, but I think it's just restating the original premise.Now consider that the conveyor is actively pushing back without moving, without needing to move, until the point where the rolling resistance of the wheels is overcome. What happens at this point? I think the runway will begin to move backwards.
Could you be more specific? Who do you think it is who cannot see it?it is amazing to me that some obviously clever people cannot see how this would work.
i certainly dont mean to be rude in anyway, to anyone.
I think so too, but I think it's just restating the original premise.Blondini said:Now consider that the conveyor is actively pushing back without moving, without needing to move, until the point where the rolling resistance of the wheels is overcome. What happens at this point? I think the runway will begin to move backwards.
http://www.youtube.com/watch?v=0ul_5DtMLhc
No it's not, you heard the pilot - "took off as normal".
Give up - it's sorted.
