It wouldn't effect the readings that much having a desk in front of the vent.
Disagree... As this case shows, it tells you if it's burning cleanly or not. On an open flued appliance especially, flue problems will cause the CO rich flue gases to enter the property. Fair enough it would probably happen anyway as the boiler got less and less air but this would accelerate it.An FGA test on a back boiler is largely meaningless anyway.
Discuss
No? Stick the probe up the down draught diverter as far as you can and get a reading (or am I misunderstanding what you're saying..?). A boiler burning badly can still pass a flue flow and spillage test.Is that not more a CO Room safety test though? .
Do Glow Worm or Baxi give combustion figures fro the CF back boilers? Otherwise surely your going by ratio alone?
I think we all know how useless it is, but the principles are good. Just the course and ridiculously easy to pass examination that need work! .Makes you wonder what we all did before CPA1 .
"Shouldn't" Yes.Disagree... As this case shows, it tells you if it's burning cleanly or not. On an open flued appliance especially, flue problems will cause the CO rich flue gases to enter the property. Fair enough it would probably happen anyway as the boiler got less and less air but this would accelerate it.
An OF boiler correctly set up should never be CO rich because the excess air is greater than fan flued boilers.
But there is no need to do any FGA on a BBU according to conventional practice. But then there is no harm and it can be useful sometimes.
Before FGA, the gas man was highly experienced at judging combustion by the flame colour. That experience has not been passed on to the more recent recruits to the industry.
Its fun to try to set up a premix boilers on the flame picture alone and then see how accurate it is with your FGA !
Tony
Discuss
