Do you really think that an oil combi would be cheaper to run than an LPG Combi running off bottles?
Yes.
Of course it would. Oil is 17% cheaper than Natural Gas at the moment. Clearly this might not always be the case, but....
LPG Bulk is very expensive and always priced way ahead of NG and Oil for domestic use; buying it in bottles it is ruinously expensive. You would never use LPG bottles for home heating unless there was no alternative.
It would give peak rate LX a run for its money, cost wise. This is the stuff used by those 'clever*' electric heaters, which are 100% efficient.
So's my toaster, by the way.
Please, remind yourself that Electric heating uses a fuel that costs at least 14p a Kw, oil is around 5p a Kw. The clay cores and German design don't make any difference, they are still 100% efficient. Like my kettle. You may not know that mains electricity is significantly cheaper in Germany than here.
The modulation ratio point is a misconception often thrown into the ring by gas installers with only limited knowledge of heating technology, the training schools only teach the basics (pipes, and how to recognise them); oil boilers have a high water content and can tolerate small loads. An oil boiler easily reaches 90% efficiency. Gas boilers need clever tricks like modulation to get there.
A Worcester Heatslave MkII nozzled down to 12Kw would be my solution, or failing that, last resort, bulk LPG. But never LPG bottles, it'll ruin you. And electric radiators! You'll have to sell the Porsche.
*only if you are a mug, who has forgotten O level physics.
http://www.oftec.org.uk/news_and_press_releases/oil-now-cheaper-than-mains-gas-for-home-heating
Yes.
