Well you started the whole quoting efficiency figures thing...I still maintain that a modulating gas boiler is more efficient and more versatile in a real-world situation than a non-modulating oil one.
@whiskeyfrank Go for the LPG boiler - the modulation means that you get a high flow rate for water but a low output to match the low demand heating system. The oil will be a compromise - if you nozzle it down to 12kW as suggested, it'll be 12kW for hot water too and that isn't going to give you a very good flow rate once the small hot water store is depleted
