Are you talking about just 'bare' LEDs? If so, as I'm sure others will have said, to run them without any resistor is very iffy - since the current through the LEDs (assuming that the voltage across each is at least high enough for it to work at all) will then only be controlled/limited by the internal resistance of the battery.OK. So I've ordered some tabbed 2032 cells and various 3.4V LED's. But, if I want to run 2 LED's off a 3V cell without a resistor (without doubling up the cells) could I use two 1.7V LED's? That'd work, wouldn't it?
It's OK, as long as you ensure the voltage of the LED slightly exceeds the cell voltage.
Again assuming you're talking of 'bare LEDs' it's the opposite way around from that - the cell voltage has to exceed the Vf of the LED (otherwise,a s Monkeh has said, the LED will not light at all). However, as I said, the current will then be approximately equal to the difference between cell voltage and LED Vf, divided by the internal resistance of battery, whatever that might be.It's OK, as long as you ensure the voltage of the LED slightly exceeds the cell voltage.
Well, just like your post (I guess that's where you got it from) they have a "1.7V LED" lighting with a a 1.5V battery - so goodness knows what they mean by "1.7V LED". It can't be an LED with a minimum Vf of 1.7V since, as Monkeh and I have said, that would not light at all with a 1.5V battery.http://www.instructables.com/id/LEDs-for-Beginners/step5/
When you get the "1.7V LEDs", I suggest you put one in series with a resistor of 47Ω - 100Ω or thereabouts across a 3V source and measure the voltage across the LED - that will give you an idea of it's actual Vf
Kind Regards, John
Indeed, but (if the Vf at such currents is, as is being suggested, a bit below 1.7V) the resistor values I suggested ought to give 15-30mA, which is not an unreasonable sort of current at which to operate, and hence for which to determine the Vf, wouldn't you agree?That'll tell you the Vf you get with whatever the current ends up being. It is not a fixed value.When you get the "1.7V LEDs", I suggest you put one in series with a resistor of 47Ω - 100Ω or thereabouts across a 3V source and measure the voltage across the LED - that will give you an idea of it's actual Vf
Kind Regards, John
OK - put the resistor up to a couple of hundred ohms or so, then.15-30mA is quite a lot. 2mA is pretty obvious when lit, 7-10mA is the max for most small LEDs, 20mA from a 5mm blue LED is an effective nightlight.
So would I - and, like you, I 'happen' to have one. However, most people in this forum probably don't, which is why I suggested just a resistor!I'd employ a constant current supply. Saying that, I happen to have adjustable constant current supplies. Not a normal household item.
