I think I may of killed my Mower today.
It started smoking, so I turned it all off unplugged it and took the plastic cover off.
Not enough particles of grass to cause a problem around the foam protection pieces.
I started it up and there was a constant spark from the central column spinning thing ( not a great description )
All contacts are secure so I put it back together and it worked ok for a bit then smoked and cut out and it smells like its struggling.
Are the sparks normal? as I wouldn't know with them being under the plastic cover.
Doesn't help that the grass was longer than normal to so maybe a bit to heavy for it and ive killed it
Model is a Flymo 380
Thankyou in advance
Thankyou in advance
