Well till now, i always assumed that the resistance of an element would reduce over time due to heat damage.
As I said, quite apart from the effects of temperature on resistivity (which is a 'short-term' issue, only relevant whilst the element is heating up), if there were long term heat damage, it would presumably take the form of loss of some of the surface of the conductor (due to oxidation/burning/whatever). That would reduce the CSA of the conductor and therefore would
increase the resistance.
you may not have the credentials, but the vast majority you do know, you not only explain well, clear and precise, you often illustrate with examples, like the light bulb scenario. May I ask, Do you have a tutoring background
Thanks for your kind comments. Although it's never been a primary part of my life, over the years I have done a certain amount of teaching, tutoring and 'mentoring' (e.g. of PhD students), although never in a field related to electricity. However, a lot of my life has involved having to explain things very clearly, either in writing or verbally, not uncommonly with intended audiences that needed 'spoon feeding' as regards some of the technical issues involved - so I guess I have probably developed some relevant skills as regards 'explaining clearly'
I certainly think, and have found, that illustrating things my examples and analogies (although someone will inevitably claim that it 's not a 'valid analogy'!) is an invaluable tool in helping people to understand. In the real world, rather than a forum, I would often try to be far more 'interactive', by trying to get 'the audience' to work out the answers for themselves, aided, if necessary by clues or questions. For example, in the case you cite, I might have asked you why you think that it is quite common for an ageing incandescent lamp/bulb to die at the moment of switch-on - and then you might have worked out what effect temperature has on the resistance of the filament, hence current through it.
Kind Regards, John
