BAS - there is no irrational fear, no fear at all - that's all in your imagination. There is an appropriate consideration of risk which you would do well to consider yourself.
At what point do you consider a full EIC becomes unreasonable ? Every week or two (holiday cottage) ? Every day/couple of days (hotel/B&B) ?
Do you really consider it to be good practice to dismantle a working system potentially hundred of times a year ? How many times do you flex a non-flex cable before you consider it to be unreasonable ? After all, we use flex cables in moving applications for a reason.
If it's considered 'dangerous' (your opinion) to not do a full EIC after (say) 6 months with one tenant, then surely it has to be much more dangerous to not do one after the same 6 months with perhaps a dozen or two different tenants (holiday cottage) or potentially a hundred or more (hotel).
Now, if you actually have anything positive to contribute, other than ignoring risk and making the frankly ludicrous and dangerous assumption that an unnecessary level of dismantling introduces zero risk of introducing a fault that wasn't previously there, then we're all ears. After all, if working on electrical system is so risk free, why bother with testing at all - if the installer has wired all the sockets right (as he will have done according to your risk assessment) then there's little point in a big chunk of the tests being done at all, no need to test new RCD/RCBOs as they'll have been tested at the factory, etc, etc.
Others have managed to temper their "enthusiasm for a full EIC" with actual positive comments. You, sadly as usual, have presented nothing but negative comments and personal abuse which was not warranted.
