Maybe it’s just a quiet time of year for diy work, with most people going on holiday ?
The manufacturer tells me the flow rates of the Spey 2 shower are:
0.2bar: 4.2 l/min
0.5bar: 5.6 l/min
1.0bar: 7.7 l/min
2.0bar: 12.1 l/min
3.0bar: 14.1 l/min
I have an incoming water pressure of around 3 bar max. I guess if the boiler output is limited to less than 14.1 l/min, then that would be all you get.
The flow rate at the existing shower on the stop is 11.5 l/min. Would it be fair to assume a similar flow rate would be achievable in the ensuite?
WB Greenstar 34CDi.
Around 3 bar.
As I say, the mixer in the bathroom gives 11.5 l/min.
Bathstore isn't the first business to go down the plughole and it won't be the last.https://www.installeronline.co.uk/b...on-another-blow-bricks-mortar-retail-outfits/
Is it because of Brexit?
Nowt to do with brexit.
Cheers.Whats more important is the working pressure and what that is at peak times
a drenching shower even with water pressure as low as 0.1 bar."
