- Joined
- 27 Jan 2008
- Messages
- 28,162
- Reaction score
- 3,416
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I say beer kits as the whole idea of pans with mash seems just too much work in my mind however the kit is very simple.
There are so tweaks one can do with a kit from type of sugar to amount of sugar and amount of water which will alter taste and alcohol level and I have tried some of these but clearly it takes time to assess the results.
But the big question is when to bottle? Once one leaves the recommended figures then the times will change so there seems to be two methods to assess when to bottle. The hydrometer readings and the air lock activity however in both cases one can get odd results.
Water will absorb gas be it air in a fish pond or CO2 in the beer and when disturbed it will release this gas. So taking a sample of beer for the hydrometer readings I find often the gas released can give a false reading. Also my hydrometer is correct at 60 degs F which is colder than the temperature at which beer will ferment so at 20 degs C the reading is inaccurate.
When my brew cooled to 16 degs C and I measured the s.g. it showed as nearly finished 0.010 but when the brew was raised back to the 20 to 24 degrees needed for the yeast to work the hydrometer reading went up to 0.014 showing not ready to bottle.
All the stuff says the reading should get lower day by day but my reading went up which got me scratching my head. So I got out another hydrometer and started some tests.
My first result was the two hydrometers altered in the reverse as the temperature changed one was plastic the other glass so reading temperature correction tables is useless unless designed for the hydrometer you are using they are not universal.
The only way seems to be to keep the brew at a set temperature and then one can look for the change without trying to correct for temperature.
Second indicator is the air lock and how many bubbles are released. However the lid on both my fermentors have cracks around where the bung for air lock is placed and sealing is some times lost giving wrong readings as far as bubble activity goes. I seal with a little butter.
With Bitter and Mild if sealed the bubbles in air lock do seem a good indicator as to when to bottle but with Ginger beer the activity was so low it was very hard to judge and again with Ginger beer I have had yeast fail and no activity also when bottled too early I had to pour them all back into the fermentor for a week to avoid the bottles exploding.
Extra sugar and water does seem to produce a brew more to my taste but this also means instead of 7 days in fermentor it can take 3 weeks so I use two methods to stop bursting a bottle. First is using screw cap bottles where the cap is weakest part the other now my preferred method is use plastic pop bottles so I can feel the pressure without opening.
The other thing is I now keep a journal detailing what I have done so I can look back and get some data as to how long at what temperature a brew takes.
With two fermentors I now transfer when near complete this removes the bulk of the sediment so when bottled some 3 or 4 days latter there is very little sediment transferred into the bottles. This is more important when using pop bottles as although one can carefully pour the first glass with crystal clear results once returned to upright sediment is disturbed so second glass becomes slightly cloudy.
Well this should I hope be a good start now it's time to sit back enjoy a pint and wait for replies and see how others get on with beer kits.
