Sorry, but I couldn't help observing that ........ then the water can also be generated with less electricity at an off peak time
I'm not sure that it's very easy to "generate water" with any amount of electricity, at any time
Kind Regards, John
If only. Personally I think it could be "interesting" in the next few years to see if legionella becomes a big thing. AIUI anything under about 45˚C is fertile breeding ground, above 50˚C will kill it over time, and over something like 55˚C is needed to be sure there's none left. Just out of curiosity, I looked at the specs for a (air-water) heat pump currently on the UK market for domestic use, from a well known manufacturer, and the maximum it could be programmed to for heating a DHW tank was 55˚C - note that's the flow through the HE coil in the tank, not the actual tank water temperature. And I'm fairly certain that it could not reach this without an unusually warm outside air temp, or using the direct electric heater.Agree; swap them out for heat pump driven well insulated tanks then the hot water can also be generated with less electricity at an off peak time
My ASHP does 60 degrees even in sub zero temps; it takes longer but outside air temp doesn't impact the final tank temp.And I'm fairly certain that it could not reach this without an unusually warm outside air temp
That is what I was trying to say, the problem is people see the advert for a free heat pump, and go for it, but the re-plumbing to use a heat pump it seems is not included, the installer does what he is told to do by the government, as the government is the client, not what the home owner wants.An ASHP is not a drop-in replacement for a gas boiler and the vast majority of properties
I personally doubt it and, if it were to become 'a big thing', it would probably be much wider than just Legionella, since many/most bacteria have similar ';environmental' requirements (for survival and/or proliferation).Personally I think it could be "interesting" in the next few years to see if legionella becomes a big thing. AIUI anything under about 45˚C is fertile breeding ground, above 50˚C will kill it over time, and over something like 55˚C is needed to be sure there's none left.
I would have thought that there would be no theoretical limit to what temperature could be achieved, regardless of outside temp. Is it not the case that, given an appropriate choice of 'refrigerant'; and pressures, one could theoretically achieve any temp, provided only that the outside temp was above absolute zero? What I don't know is what happens to efficiency when the outside temp gets low, and that may possibly be 'the crunch'.Just out of curiosity, I looked at the specs for a (air-water) heat pump currently on the UK market for domestic use, from a well known manufacturer, and the maximum it could be programmed to for heating a DHW tank was 55˚C - note that's the flow through the HE coil in the tank, not the actual tank water temperature. .... I also noted that the seasonal efficiency rating was only about 1.8 - very much not the "around 3 for a rule of thumb" figures often quoted (including my myself in the past). That would be taking into account the reduction in efficiency when the outside air is cold
Indeed - and, as I added, it (or any other pathogen) also needs nutrients, and I'm not sure where they are coming from in ('clean') domestic water.Legionella is rarely a problem in domestic hot water, as it's not just about temperature - to grow it also needs static or recirculated water, neither of which is likely.
And have you looked into how much lecky it uses when it's sub-zero outside ?My ASHP does 60 degrees even in sub zero temps; it takes longer but outside air temp doesn't impact the final tank temp.
Yes, those seem to ring a bell. But in most retrofit environments you aren't going to any much heat of the rads with a 35˚C flow. Crank it up to (say) 45˚C and the CoP drops off significantly. As I mentioned above, for the model I looked at the seasonable rating was around 1.85 - a long way from 3, and a lot more lecky used than you might think.You're looking for coefficient of performance charts I think; most ASHP are given a rating of how much heat they produce for the electrical energy they consume and the typical test conditions are to have the pump produce 35 degree water at an ambient temp of 7 degrees. At these a typical efficiency is at least 3x, which is on par cost-wise with a gas boiler
Much as already suggested. Except they are being pushed (in many cases) as simple replacements - before the installer rides off on his horse.These "I switched from a gas boiler to an ashp and my electricity bill rocketed" stories are nearly universally caused by completely unsuitable properties. An ASHP is not a drop-in replacement for a gas boiler and the vast majority of properties need significant upgrade before an ASHP makes sense as a heat source
Presumably they manage to absorb these minimal nutrients.One thing I've never really understood is how Legionella (or any other bacteria) can seemingly manage to thrive and breed in water which contains minimal nutrients.
Don't need to; I know that it doesn't use an inline resistive heater, because it hasn't got one, and it isn't in control of the tank immersion. COP is lower (note: I never said it wasn't) but it's still higher than an immersion (COP 1)And have you looked into how much lecky it uses when it's sub-zero outside ?
As mentioned, these heat pump systems tend to fall off in performance and at some point will fall back on an in-line immersion heater.
True, but if the installer hasn't upsized the rads to be useful with a low flow temp then it's probably because his horse couldn't carry themin most retrofit environments you aren't going to any much heat of the rads with a 35˚C flow
Hmm, it seems one ought to be making improvements elsewhere so that comes up; the reasonable payback period for the (imho excessive) cost of the pump over simple resistive heating at a sub-2 COP is lengthyfor the model I looked at the seasonable rating was around 1.85
I know the equation/have no issue with the maths side of it, so I can appreciate ahead of time the power use.. But in a nutshell, my ASHP does OK; it was cheap to buy, qualified for the RHI (though not at the best rate but I made up for that in other ways) and adequately heats the house without being flogged. It runs for about 250 hours a year in CH mode producing 26 degree water so hopefully has a fairly easy time of it. Service life wise I'm expecting better longevity than a combiand a lot more lecky used than you might think
They presumably must do. However, the outbreaks of Legionella one hears about are not in domestic premises(where the water is pretty clean), so maybe they generally happen in situations where the water is much more contaminated with what some bugs may be able to utilise as 'nutrients'.Presumably they manage to absorb these minimal nutrients.
As I understand it, a high proportion of substantial Legionella outbreaks have been related to 'cooling towers' of one sort or another. Although one quite often sees concern expressed about 'the risk' in domestic environments (as per your comments), I have no idea as to how common actual 'incidents' in domestic environments are.We did have a legionella outbreak near here some years ago - in that case, "cooling tower" A/C system ...
I'm sure that's true. However, as far as I am aware, most of the 'impurities' are minerals, whereas most living organisms (maybe Legionella is an exception {as, apparently, are some very deep-see a creatures} I'll try to discover) need organic nutrients, which I imagine are pretty lacking in most tap water (but, again, I may be wrong).Tap water is far from pure - I recall reading/hearing some time ago that excessively pure tap water causes complaints (to the water companies) about it's poor taste.
Indeed so. As I said, the majority of well-publicised outbreaks seem to be related to cooling towers.The two risk factors with legionella are standing water at a healthy breeding temperature, and a process that creates airborne droplets. The airborne droplets get breathed in and so find an entry route via respiratory tract. Clearly a cooling tower system meets both of these with lukewarm water dropping through the slats creating a lot of droplets which are carried upwards in the airflow.
Who knows? We certainly hear very little about domestic Legionella issues at the moment, we don't know whether your suspicions that DHW temps will fall will prove to be correct and we don't know whether, in an 'occupied' domestic environment it would result in a problem, anyway.... In a domestic setting, header tanks in warm attics - particularly if the property is empty - are a prime suspect. Then add a shower to create plenty of droplets ... Normally, the DHW cylinder is kept above 50°C so not a problem. I can't help thinking a lot will be kept less hot with heat pumps which then intruduces a risk.
As suggested, in "clean" water, growth rate is slow, hence not generally a problem where systems are in regular use.
Very true. Copper is very toxic to micro-organisms (and also higher forms of life, like humans, at adequate levels of exposure). Given your 'predictions of doom', I'm a little surprised that you have not noted that copper pipework is gradually being replaced by plastic!Also, domestic systems are generally copper which has natural antiseptic properties. I gather stainless steel cylinders are commonly used with heat pump installations, and SS doesn't have such antiseptic qualities.
Such things should have gone away a long time ago, and any new system with a heat pump would use an unvented cylinder.In a domestic setting, header tanks in warm attics
The pump DHW controllers have built in control for this; once a fortnight both the ASHP I have take the tank to 60 degreesI can't help thinking a lot will be kept less hot with heat pumps
