That looks more like one set of readings from a Kane 400.
That 3% is a reference level, and it is printed on every results slip from a Kane.
we have checked filter at tank and is ok
That's what I said.whatdo iknow said:that would decrease the fan speed
I don't follow your reasoning.if anything this is under fueled not under aired.
oilman certainly knows what he's doing.oilman has put his finger on it
Well, that's possible.whatdo iknow said:putting it simpley
oilman suspects that air may being drawn via the aga oil suppy.
this will restrict the oil to the burner causing the pump to partialy cavitate
result under fueling
Does under-fuelled automatically mean that it's over-aired?over aired
OK.flame cooling
flame impingement
which is why im im not happy with the combustion figures
cause filter or draging air from the aga
I don't know you why you've decided that I want you to suck an egg, or that I want to play with you.now fetch an egg and show me how to suck it
ive been commisioning burner since 1983 on oil gas and bio gas
and not on toy burners
generally up to 1.8mw
dont play with me
I don't find your teeth-baring exercise to be very impressive. If you're right then you're right, but you seem very defensive.this burner should read 4% O2 24% excess air 0 PPM CO AND 11% co2
dont fool with me i do it for a living
