Large rubber gloves and get yer hand up there!!
no over the rim freshener. I rent the flat. I'm pretty certain the wipes are causing the blockage.Did you had a over the rim fresher?
Do you own your flat or rent?
If you can't do it, best call a plumber, might need to remove toilet pan to clean out and check what is causing the blockage.
Daniel.
there's no need to be rude.I think you are taking the p**s
thanks, Dan. The landlord doesn't actually have a key. I'll order a plunger online.If you rent, get the landlord to send a plumber round with keys. . You don't need to be there.
A red corrugated one. Blockage cleared after about 15 mins of pumping.
meant to write about 5 minutes! I don't think my arms could take 15 mins - they're only small lolA red corrugated one. Blockage cleared after about 15 mins of pumping.
Takes all sorts I suppose.
Personally 15 minutes would be a bit underwhelming.
