Freddie said:jbonding said:so youve not read it, cant you get someone else to read it for you,lol read it the benefits are it controls suction. the reason for not putting the waterproofer in the top coat appart from ashlar work is if any water gets behind, which it will, it wont get out as easily and when the frost comes you know your phones gonna be busy. if you were ever taught about plastering and rendering and i dont mean of your mate or forums you would of been told render is a finish, the colour and texture can be done without paint. applying pva mixed with water cement and a couple of handfulls of sand mixed too a slurry and applied with a roller similar to a spatterdash coat is a problem?Freddie said:Does it say for use externally?
Why when your wall has been prepared to accept cement render as has been done for years do you cover or mix a sticky elastic goo all over it ? what possible benefit could it be?
Wht oh why wouldnt you put waterproofer in the finish coat of render?
Why not paint? i understand that a building has to breath but as Oilman will tell you that paints are designed to let that happen.
You are trying to back track now and muddle around.
You said --NO WATERPROOFER IN THE FINISH COAT OF RENDER.
You said --APPLY UNIBOND/PVA TO THE WALL OF THE HOUSE WITH SAND AND CEMENT
Her we go waffle waffle muddle it all up and try and confuse to hide your errors, i havent quoted you word for word because your errors are so blatently obvious.
Nobodies disputing the cleanliness and sound prep job done to the wall just your ridiculas reasoning for using unibond/pva in an outside application where it will do nothing but be depremental to the job.
Your reasoning for no waterproofer in the finish coat may have some standing as regards frost damage if it wasnt for the same thing being able to hapen if the water got behind the scratch coat and frost damage blew that off the wall in the same manner you describe, infact your argument on this is self defeating as it is obvious that waterproofer should be applied to all coats as the more ways of keeping water out the better and the same applies to paint as paint is also a protective covering against the elements and letting the surface underneath the paint breath at the same time.
Your arguments dont stand up and you cant even answer basic questions as regards the use of unibond/pva in exterior situations
Freddie said:Jbonding
I have used PVA glue ( Evostick and others ) for 15 years manufacturing Pine furniture and now fire surrounds.
As a glue it will only work under extreme pressure of wood clamps etc, otherwise it is just a sticky substance that will dry but turn to poo when it gets wet again, and is easily washed off your hands or clothing.
Once turned to poo it never goes back to the same dried state as before.
I dont doubt it's use's for sealing an interior wall or for dust sticking a floor.
It will not however stick things to a wall which will get damp or wet again.
It will do nothing to aid tons of render to an exterior wall infact it will most likely ruin the natural cementing action once it gets damp again.
STILL YOU HAVE AVOIDED THE POINTS YOU HAVE CLAIMED ABOUT THIS STUFF AND YOUR BOZO CLAIM OF HOW TO RENDER AN OUTSIDE WALL WITH WATERPROOFER.
If you are going to give advice to people on a forum who are going to take it as gospel and follow it which may end up costing them thousands of pounds, please do put your name and address up so at least they can come round your house and shove a gallon of unibond/pva up your backside sideways.
Personally i think you are a clown--a fool would have more sense.
bonds wood and paper and isnt that what 7 year olds do, i think hes having a dig at you freddie,lol.what mudster said about pva and tiling is a completely different thing like i said pva has more than one use (kids glue).ive not done any wet dash, bring the post up. bring up the other post about 5-6mm and lets see if theres more to the post. ive not advocated pva on its own as a bonding agent for render, bring that post up aswell.you didnt understand the post about the scratch coat, i didnt say the pva was the way to go , iwould soak it aswell. the question was would the top coat still stick with the pva to control the suction. The answer is yes because the scratch coat provides the key not the pva, that controls suction and seals dust. posting pictures of rendered bungalows will look nice so does the room in diy sos,changing rooms,1hour makeover and so on.legs-akimbo said:Derrrrr! he said it bonds wood and paper, aint that just what seven years olds do with it.
He also states it acts as a primer for tiling surfaces and when i find it I will post up again mudsters very informative post as to why it doesent. That guy has probably plastered about as much externally as you have J bonding which is about as close to **** all as you can get. Are you not the same Jbonding who stated you have not done ANY wet dash (hurling) in your life, who clearly has done no dry dash judging by your ill informed post a while bak that advised to dash onto a 4to 5mm wet render coat, thats almost a skim You advocate pva while simultaneously dismissing out of hand exterior paints ...the likes of sandtex that have been around for years on end. Where you live do renders without waterproofer not soak in driving rain, then when the temperatures go sub zero does this water not freeze like everyone elses????
Why on earth would you want to p****d around with uni bond to reduce suction before a scratch, when the blindingly obvious alternative is as simple as a b c..........Guess what it is!! its a hose pipe and its water, No great revelation there, though it may be to you.
I have a Bungalow of 2300 sq ft to start in a couple of weeks time and am gonna post up regular photos as we progress, look and learn, I think you need it.
Freddie said:jbonding said:Freddie said:Jbonding
so you dont beleive a word of it ,pva must be a con, ive not had this much abuse since i recomended my mate to paint his bike with emulsion,lol.read the tin, render will absorb water and dry out, waterproofer in a top coat will absorb water but will not dry out, probably freeze out. i advise you stick to wood glue , MDF and your trusty router with your quarter inch bit,lol
Still not answered any questions i asked and now try to say i dont believe something i havent stated a word about.
I am afraid you have lost any credability you had here and have shown youself to be just full of s h i t --- i suggest you dont try and give people your hocus pocus hair brained advice anymore and stick to bed time stories for the deaf.
Mudster said:The information in the internet sourced PVA advice is misleading, legs mentioned a post I made some time ag o on screwfix, I'll paste that here, it explains why PVA should not be used as a primer to tiling.
As for it's use in Plastering, I've never fully understood this so would prefer to neutral on that point. What I do know about is tiling.....and generally the misinformation provided above is something I come across on a daily basis.
Pasted post as follows:-
I'm a professional tiling contractor, I now mainly specialise in natural products but over the years I've stuck up (or down) every type of tile there is.
I have to give guarantees for my work (many of these projects are commercial such as sports centre showers and changing rooms). For me to be able to give guarantees I need to follow strictly the specification of the adhesive manufacturers.
Ardex, BAL and Nicobond are the three suppliers I use most. Their products are similar in many respects, sometimes one will make products the other don't, and I also find some of there products more useful in different applications. All three of them have one thing in common, they all specifiy that under no circumstances may PVA be used before using any of their adhesives. If you do all guarantees are void.
OK why then? Well I asked this question to Ardex when I once had problem, I'd tiled a bathroom that had been constructed in 25mm Marine ply. Thinking he was doing the right thing, the builder got his guys to seal the ply with unibond PVA...I wasn't aware of this.
I tiled it and 6 months later every single tile fell off the ply, the adhesive solidly stuck to the tile but came clean a whistle off the ply.
We had Ardex Technical down to the site to compile a report, the basis of which was it's the PVA that causes the problem.
When you treat a surface with PVA it partly soaks in and parlty sits on the surface of the substrate much in the same way as wallpaper paste.
If PVA gets wet it becomes slightly live again, it doesn't completely return to it's liquid state but it becomes sticky.
When you spread tile adhesive onto the wall, the water in the adhesive makes the PVA live and stops the adhesive from penetrating the substrate and providing a mechanical grip. Basically your tiles, grout and adhesive are being held to the wall by a thin layer of PVA.
Most tile adhesive works by crystalising when it sets (some are slightly different such as epoxy based ones) but generally they all work the same way. Once the adhesive starts to set crystals from and expand into any imperfections in the substrate surface (at a microscopic level) to create a grip. PVA stops this process by creating a barrier between the substrate and the tile adhesive.
Ok so whats the difference between this and Ardex or BAL primer, well basically the tile manufacturers primers soak right in to the substrate and stop the sponge like "draw "effect but they don't coat the surface in any way, they are an impregnator as opposed to a barrier.
I hope this clears up any misunderstandings.
legs-akimbo said:Bravo mudster, and as you would be well aware there are many a tiler still using pva in a detremental manner as you have outlined in your superb post. In the same manner there are plasterers doing exactly the same thing and J bonding is a prime example of a tradesman being over reliant on a product that does a specific job but is simply not a cure for all ills. Your post more or less reiterates Freddies points in full and while it is all well and good being able to relate to certain pdf's or extracts from the internet J B only the wealth of experience will tell you what works and what does not...Forget what the manufacturers tell you ( to a large extent) learn from those who know better and be humble enough to take heed and generate an informed opinion, I may be blowing up my own ar*e, but there is not a man I have met who can do my job better than me!
legs-akimbo said:but there is not a man I have met who can do my job better than me!
