- Joined
- 8 Aug 2019
- Messages
- 32
- Reaction score
- 0
- Country
I have a traditional gravity, pumped CH system, tank in the loft, cylinder in the airing cupboard, digital thermostat in the hall way, electronic timer in the kitchen, Greenstar Ri boiler in the garage in a two story house - all fairly typical.
Boiler is about 5 years old, as is the pump and honeywell - all replaced together.
Suddenly, the there is no hot water - my limited diagnosis so far...
The boiler and central heating pump and honeywell will not fire up or operate and run under any auto or manual command.
The thermostat in the hall has power and appears to be functional
The timer in the kitchen has power and appears to be functional
The thermostat on the water cylinder is set to 70 degrees and altering it makes no difference
Altering the hallway stat makes no difference and I can see the symbol that calls for heat illuminated
Altering the thermostat on the boiler makes no difference
The boiler solid blue light is permanently illuminated and is not flashing
There is no green 'pilot light' illumination on the boiler (little flame symbol) I know they don't have a traditional pilot light and this is just a burner operation LED
I've tried to manually adjust the Honeywell 3 way valve lever but it appears lifeless and doesn't automatically revert to a previous position under it's own power as I've witness previously when I've tried to diagnose other issues years ago - the valve doesn't appear to have any power to it
The central heating pump does not run at all in any condition or command
So, in summary, everything seems to be functional except the pump, honeywell valve and as a result(?) the boiler will not ignite, fire up and do it's job.
That is about the extent of my diagnosis skills and I'm not hugely familiar with the protocols of each part of the system from an electrical perspective. No circuit breakers are blown on my distribution panel.
The immersion switches on and lights up, but obviously not a permanent solution beyond having a shower today.
Any clues where I go from here - why is the boiler not firing up and the pump not running and the 3 way valve just as lifeless?
Really appreciate any further checks, tests and diagnosis tips.
Thanks in advance.
Thanks in advance.
