Christ, now I'll be walking funny all day .
But installing an oversized boiler will not compensate for an inadequate flow rate.I know in this case it`s not a combi but most installers fit an oversized combi boiler because the higher the kilowatt the better the litres per minute, I know on paper to all you `breakdown` engineers,this is wrong but here in the land of reality people want hot water bursting out of their taps.
Hi all, Had a rep round today regarding the green deal, he did a full energy survey on the house which had had quite a few extensions added since the boiler had been fitted. When I pointed this out to him and suggested that a bigger boiler may be required , he said " you must have the smallest boiler your property will allow so when it works it has to work flat out only then will it save money because only then will it condense, personally I thought he was talking crap, but I thought I would run it by you guys just to check. Any comments greatly appreciated. thanks mark
He, most of us pros here as well as the Energy Saving Trust all know that a boiler should not be oversized.
If the flow is good a larger boiler will just give hotter water.Assuming the initial flow rate at the mains is good,a larger boiler will give better litres per min at hot tap.
Assuming the initial flow rate at the mains is good,a larger boiler will give better litres per min at hot tap. This isn`t good practice, but it`s what`s done.Seen it over and over again.
Chan, All combi boilers work on 24kw for heating rads
If you install a boiler which is larger than necessary to give the required temperature rise at the maximum available flow, then all you will get is hotter water. You will not get a higher flow rate.No. It will give more hotter waterIf the flow is good a larger boiler will just give hotter water.Assuming the initial flow rate at the mains is good,a larger boiler will give better litres per min at hot tap.
