- Joined
- 27 Jan 2008
- Messages
- 25,733
- Reaction score
- 3,049
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My gas water heater, I hope it never boils the water as that would mean there is a fault, so should not call it a boiler (Am I doing a Wilson?) anyway my water heater has a quantity of water kept hot to reduce delay getting hot water to tap, so even when no central heating or domestic water is being used, it still uses some gas. It does mean there is not much delay getting hot water though.
So kettle holds 2 litres, likely need to run 1/2 litre to run out cold and warm pipes, then I boil a cup of water, 1/4 litre maybe, so by next use the warm water in kettle is cold, so what is the point?
Two kettles similar design same make, one you can stop mid flow and adjust how much water, the other is a set amount, the former takes longer to boil but will fill a large mug, I would assume the adjustment bleeds water back into reservoir, as does stop mid flow, so the larger is not as efficient as the smaller model. However both boil a cup full of water only, rest of the 1.6 or 2 litres remains nearly cold, just can't see point of filling with hot water.
Even with old kettle if boiling one cup of water you would need to run around 10 cups of water to get a cup of hot water, yes quicker as water already warm in reservoir in gas water heater, but can't be cheaper.
