D
Deleted member 174758
I also think the problem is the depth of the bit. Cores need to be broken out with a hammer and chisel from time to time to allow the bit to go deeper. I started out with a basic set of TCT core drills and they could only do about 2-1/2in depth as against my present Marcrists which do a good 6 inches. Who says size isn't important! I'd agree with what others say about being wary of using am SDS+ with a large diameter core bit - the cheaper drills just don't have a clutch so if the b*gg*r snatches you might end up with a sprained wrist, or worse. I've had a few snatches in the past but fortunately not too serious (mainly my pride hurt!). Core drills are designed with proper heavy duty clutches and will prevent you getting injured.
