- Joined
- 8 Jan 2011
- Messages
- 591
- Reaction score
- 35
- Country
Since you seem to like applying maths to electrical problems, perhaps you would like to try this one....
Still waiting for him to post his solution to the problem he posed.
(S)he has now more-or-less acknowledged that (although (s)he didn't work out the answer before posting, hence didn't realise (s)he'd created an impossible set of numbers!), in mathematical terms, the answer given by several of us (first by Spark123) is the coirrect one - and (s)he has certainly indicated that (s)he knows what mathematical process has to be undertaken to get an answer. However, as you will have noticed, I'm interested to know how far his/her mathematical skills actually go.Still waiting for him to post his solution to the problem he posed.Since you seem to like applying maths to electrical problems, perhaps you would like to try this one....
Of course it doesn't. To be a competant electrician, you need to be able to do simple arithmetic, nothing more; even working with the infamous adiabatic equation (an adiabatic equation, as I always have to remind people), only requires the most basic of understanding of the concept of algebra and the ability to plug values into an equation.I'm not brilliant at maths. I think I got a grade C at GCSE, but Carol Vorderman I aint. Does that mean I'm a bad electrician?
ooh, that would be toasty - wouldn't want to be standing too near when "testing" itGiven a supply with an off-load voltage of 230V and a PSSC (acronym means "peak short circuit current") at the point of connection to the load, of 1150A, what is the maximum power that can be delivered into a resistive load by that supply?
No, because you realise the limits and so are able to deal with it - whether that involves using the books a bit more, checking with a colleague, or using some ready made tables, or whatever. Mind you, I can't think of anything where the actual calculations are that difficult (doubt if a GCSE is needed) - as long as you know what they are. The example that kicked this off is a bit contrived and I can't see any real reason for having to do it for real - work out the total length of cable perhaps, but in general all you are interested in is R1+R2 and R1+Rn not exceeding certain limits.I'm not brilliant at maths. I think I got a grade C at GCSE, but Carol Vorderman I aint.
Exactly.Basic mathematical skills are needed for some domestic work - most circuits are generic anyway and it's all been worked out for you by the heads at the IET. Most domestic electricians only have to read a meter and copy the results.
That's really electrical engineering. 'An electrician' does not really need to deal with any of that, although I'm sure that many are quite capable of it.Then/if you progress into more complex engineering and dealing with imaginary numbers and 'j' notation is when you can scratch your head a bit.
Exactly - and no electrician should normally ever need to do anything much more mathematically complicated than that. As others here are hinting, dealing with 3-phase currents is perhaps the most 'mathematical' thing which will be required, and even that virtually never for those who work only on 'ordinary' domestic installations - even my house, which, in a literal sense, has a 3-phase supply is, in reality, just three single-phase installations.I can do cable calcs and ohms law dead easy, and the adiabatic if I sit down and think about it, and that's about as much as I've ever needed to know.
No, but I bet you look c*** in a tight dress.Does that mean I'm a bad electrician?
Can the load have a negative resistance?Given a supply with an off-load voltage of 230V and a PSSC (acronym means "peak short circuit current") at the point of connection to the load, of 1150A, what is the maximum power that can be delivered into a resistive load by that supply?[/color]
Hey, you're giving him/her clues about the magnitude of the answerooh, that would be toasty - wouldn't want to be standing too near when "testing" itGiven a supply with an off-load voltage of 230V and a PSSC (acronym means "peak short circuit current") at the point of connection to the load, of 1150A, what is the maximum power that can be delivered into a resistive load by that supply?
Indeed - but that is equal true of every relevant aspect of electrical work, not just (the small amount of) maths.It's only dangerous when someone doesn't know the maths and either doesn't realise or doesn't care that they don't.
NoCan the load have a negative resistance?Given a supply with an off-load voltage of 230V and a PSSC (acronym means "peak short circuit current") at the point of connection to the load, of 1150A, what is the maximum power that can be delivered into a resistive load by that supply?[/color]
Insufficient information - it's not possible to calculate from individual current magnitudes only. However, if you make assumptions about power factor for each load then that changes.So a nice and simple one, if a 3 phase + neutral system has a current draw of 10A on L1, 20A on L2 and 40A on L3, what is the neutral current?
