There your rather wrong. I'm not an electrician, and nor is BAS - and, to the best of my knowledge, nor are several of the otehrs who have particpated ti this thread.John - I'm not the spark here, everyone else is ...
It's a bit odd that you say that, since you go on to give a very good mathematical answer to it!John - your queetion seems to me to be a spark question not a maths question - never did that in my degree ...
Spot on. If you sketched the function, or merely thought about the nature of the problem (as you've done above), you'd realise that there is only one turning point, which is a maximum, so you wouldn't really need to look at the second derivative. The only bit you haven't done is the 'spark' bit - actually 'creating the function', but that's really very easy (I can demonstrate if you wish). The resultant function is a bit tedious to differentiate, but one just has to plod through it.However, in respect of your spark question, I think I see the issue - As the resistive load increase, (which contributes to higher power), current falls (which contributes to lower power). I'd therefore investigate creating a function for power that I could differentiate. Once differentiated, I'd set the first derivative to zero to the find maximum power, then check whether it's a maximum or minmum by producing a second derivative. If the second derivative was less than zero, I'd have confirmed the maximum exists and provide you with the answer.
.... maximum power is always delivered to a load when its impedance is the same as that as the 'internal impedance' of the power source. In the example I gave, the maximum current of 1150A occurs when the supply is 'shorted', hence the only impedance in that circuit is the supply's internal impedance. At 230V, that means that the supply impedance (voltage/current) is 230/1150, namely 0.2Ω. Hence, for maximum power delivery, we also have a 0.2Ω load. Total impedance in circuit is then 0.4Ω, hence a current (voltage/impedance) of 230/0.4 =575A. Power in the load (current squared x impedance) is therefore 575 x 575 x 0.2 = 66125 watts. SimplesJohn But prey tell master what is the answer and the way to proceed?
OK, albeit well 'off-topic', just for fun. You may well know this one already - so, if you do (without having to think), perhaps you would leave it for someone else to muse over ...if you'd like to give me a proper MATHS question, Pure, Statistics, Mechanics and Game Theory are my specialist subjects - I'd try to oblige ... ?
That would probably make the problem very difficult to solve - unless, of course, you believed that the heavier ones would fall more quickly !!Am I allowed to drop them on the floor first
Not sure if this counts as "one weighing" or not but I'd put all the stacks on the scales at the same time & then remove a coin from each stack until the weight dropped by 11gOK, albeit well 'off-topic', just for fun. You may well know this one already - so, if you do (without having to think), perhaps you would leave it for someone else to muse over ...if you'd like to give me a proper MATHS question, Pure, Statistics, Mechanics and Game Theory are my specialist subjects - I'd try to oblige ... ?
5 stacks, each of 10 visually identical coins. You are told that all the coins in 4 of the stacks weigh exactly 10g, but all of those in the fifth stack weigh 11g. You have an accurate set of weighing scales. How do you determine which stack has the heavy coins by undertaking just ONE weighing?
Kind Regards, John.
Kind Regards, John.
Dizz,
Earlier I asked,
1/
Two farmers meet at crossroads and get talking.
Each have a herd of sheep.
One says
"Sell me two of yours and I will have twice as many as you"
Tother says
"Sell me two of yours and we`ll each have the same"
How many sheep had each farmer?
2/
(Best spoken not written but here goes!)
If a brick weighs 7 pounds and half a brick then what does a brick and a half weigh?
Seems no one answered!
Two weighings is easy peasy back of fag packet stuff.
It is the one weighing that makes it .
