I View media item 55897
I was using an extension plugged into a plug in meter (from Maplins, model 2000MU, max current 15A). I was running a heater, some lights, and a drill. As you can see the Neutral pin of the extension's plug has stuck in the meter and the meter shows a burn mark and warping of the plastic due to heat.
Is it the plug or the meter that was likely to be the cause of the fault, or something else?
