It looks like BT have withdrawn their night busying facility.
IIRC this used to apply something like a 30 Kilohm loop to the line, which was recognised by the exchange equipment as the signal to initiate the night busying.
You might be able to use call diversion in a similar manner by diverting incoming calls on all the unused lines to the same number, but I don't know if this would work if you have auxilliay working lines.
Putting a loop on the line, whether with a resistor or a dead short works for short periods, but left, say, over night, it could upset the exhange equipment, which may see it as a fault, and disconnect the service.
I did encounter problems a few years back where a rack of something like 120 modems were installed at a customer. The equipment used to go through a housekeeping routine at night, and busy out the lines as it did so. The exchange saw the busy out time as 120 simultaneous applications for dial tone, but no dialled numbers, which it regarded as a fault condition and shut down the lines.
