I'm trying to run a feasability study into replacing a boiler and would like to calculate a new supply cable size. I've tried several online calculators and have varied results. The supply will be fused at 200A to supply a 115kw boiler on a 3 phase supply at 400v over a run of 27m. The isolator will be at 23m from the fused supply with a 4m feed direct to the boiler. The cable will have to run for 5 metres underground but the rest will be through conduit or clipped to walls etc. I've been told that every meter counts on this kind of run, but the calculators (usually with a 70mm result) do not change their suggested size from the 30m mark up until over 100m. Any suggestions, formulae or links would be appreciated.
Thanks.
Thanks.
