Hi all,
First post here but been a frequent visitor and avid reader of the site.
Just bought an electric double oven to replace my single oven.
Budgets tight and spent more than i wanted to on the cooker so looking to save myself some pennies by installing it myself.
I'm not taking this task lightly or under estimating the job at hand,hence why am here consulting with you guys.
So bit of info for you in regards to the job
House was just built 6 year ago so i'm assuming the electrics are sound
The oven i've bought is the hotpoint hue61 it has a max load of 10.7 kw and hotpoint say 45a required and that's my problem i only have a 40a mcb.
The consumer unit is a wylex the current mcb is a nsb40.
As i understand it wylex don't do a nsb45 0nly a nsb50.
So my question too you guys are should i replace the 40amp with a 50 amp?
Also my current cable i intend to use is two metres long and 6mm is this safe to use? or should i go for 10mm from cooker to hardwiring point behind cooker.
Thanks to all that take the time to read and reply to this post,look forward to reading your replies.
