... and that's if one knows that there IS a 'fault'. What I illustrated was found purely by accident when a floorboard was lifted. The circuit had been continuing to work fine, and there was nothing to suggest that there was anything wrong - and (as one might expect from the photo) the circuit IRd perfectly fine with that 'fault' present!
Indeed - but, where it was, no water was ever going to get splashed on it - so, had I not stumbled across the damage, I would never have been aware of the problem, even if I had 'fully tested' the circuit.
I only found mine when I switched a light on and the circuit tripped, assuming it was a blown bulb I replaced it but still tripped. In the loft I found about 4ft of the switch drop stripped bare on the top and eventually the bare copper (3/0.029“) had popped out of the PVC remains. I spent half a day looking and making repairs to the other bits which had been chewed.
If it had not chosen Christmas Eve to 'pop out' I could have easily had a nasty surprise when putting Christmas decs away later.
While at it I took the oportunity to do away with the borrowed neutral and resplit my lighting circuits.
