Well you bloody well shouldn't have.I have burnt……plastic, waste oil in it so far
Why not?Well you bloody well shouldn't have.
Great find!Here's one link to a generic wet woodburner setup, there are plenty more.
When I first got my first flat roundabout 9/11 was an inside job, My landlord said use the gas for heating, electric is about 3 times the price of itAnd at the moment in the UK electricity is between 3 and 4 times the cost of gas per kwh
House? You have a house now?Why not?
I will say to you what I said to the pricks That need to be terminated by the fake vaccine on the builders hub and the mig welding forum "It is my house and I will do as I please in it!"
Google broken over there is it?Great find!
But do we need all of those tanks up there though? Will just one not do?
Rhere are 4 ports on that stove where mine only has 2
How do other fuels like firewood coal and heating oil equate to this in cost per kwh?
I would be mind full of that from someone wanting to sell you a wood burning stove. Still no mention of coal and heating oil prices thoughGoogle broken over there is it?
A Wood Stove or Central Heating, Which is Cheaper? (2022)
A wood burning stove may be cheaper to run than you think! Find out how much heating your house with firewood really costswww.pentlandbiomass.com
the sketch shows an indirect water tank, a cold water tank and a feed expension tankThat sketch shows a hot water cylinder.
DHW???If you want hot water heated by your woodburner you'll need a dhw cylinder.
So a header tank is something I can just make myself right out of an old 45 gallon drum? and just one tank only?There may be unvented dhw cylinders that are approved for direct connection to a woodburner but the simple solution (header tank) will be much cheaper and easier.
Thats another interesting one you post, though I guess it will depend upon when it was last updated.Confused About Energy :: Fuel Prices
Current energy prices for a range of household fuels, including, gas, electric, economy 7, coal, smokeless coal, wood, LPG, propane, butane, heating oil (kerosene).www.confusedaboutenergy.co.uk
Interesting - price/performance ratios have changed significantly since i last did these sums.
Which is odd. Gas price has doubled since i did these sums, smokeless cost has nearly doubled, firewood don't know never bought any.
So if I buy one of those bottles I can fill it up at Morrisons LPG pump?House coal is banned for domestic use in England now.
LPG you can fill at the petrol stationBottled gas- yes it has gone mad. Have a look at these or similar if bottled gas is a permanent requirement .
Again not done the sums recently, looked about 5 years ago and i would have been in profit after the 5th bottle fill. But at the time i was only using 1 bottle a year (in the caravan) and mains gas was much cheaper at home.
Yep, thats exactly the plan & vehicle LPG was a LOT cheaper than Calor etc. Calor etc does get cheaper if you have bigger bottles.So if I buy one of those bottles I can fill it up at Morrisons LPG pump?
What with thing like MI5 blowing up the Russian pipe line and stuff, gas is in short supply and hence over priced (they want everyone off of gas and on electric, its part of agenda 2030)
So you are saying it is unsafe to have a sealed system with no header tank? So dose my header need to be metal and air vented at the top then? and what size tank needed?
Is that on the boiler or the radiator?
Is this what they call Thermosiphon, I cant see it working i still see the need for the aid of a pump
Dont know
I can just about get a 22mm pipe inside of the pipe of the boiler, but dont the radiators use 15mm right?
I dont see any prices on there web site! are they just the manufatures, where can you buy the bottles?Yep, thats exactly the plan & vehicle LPG was a LOT cheaper than Calor etc. Calor etc does get cheaper if you have bigger bottles.
