I'm having continuous issues with my central heating. I've tried all sorts and there is no improvement so I'm reaching out online to see if anyone has an ideas or if anyone has experienced something similar.
To put it simply, there is always air in the system that I can never fully clear. Radiators while trickle and gurgle with air inside. Every day I need to turn off all rads aside from one or two, then bleed an upstairs radiator - It’s like I need to force the air out by focusing on a single radiator at a time.
Air that does come out seems to be in the water. I will get little 'whoosh' of air, instead, water will come out that fizzes, spits and hisses. This can be a nightmare to get to this stage, but when I do, you can almost feel the radiator and the water being expelled getting hotter.
Following this the radiators will all be screaming hot. The house will be tropical within a matter of minutes, but then the following day, I get little heat from the downstairs radiators and the process starts fresh.
In the process of troubleshooting (and normal upgrades) I have had
-new boiler (5 year old now, Baxi)
-all new radiators bar one (which is probably 10-15 years old).
- Most pipework replaced, just not the initial run out of the boiler. Backbone upgraded to 21mm from 15mm
-I’ve taken all rads off and flushed them through one by one with a hose
-Drained and refilled the system multiple times
-Balance by a heating company
-Turned off (lockshield and thermostat), one at a time, each upstairs radiator (including the oldest) to see if one radiator is causing the issue - no change
But the issue persists and I’m at my wits end as I need to spend half an hour+ a day fighting to get air out of the system before I can get some heat. It makes it pointless letting the system come on and off by thermostat as I until I mess with it, it will not heat rooms. I'm fighting with it daily, running it until I sweat, and the I leave it until I repeat the ordeal the next day.
Does anyone have any ideas? This is a 28Kw Baxi combi, closed system, eight radiators, most are Stelrad (6/8). Inhibitors is used and there is a magnetic grot collector on the return to the boiler (forget the name for it).
