- Joined
- 14 Dec 2016
- Messages
- 67
- Reaction score
- 10
- Country
When you say it doesn't work, is the boiler producing heat when only hot water is supposed to be on? You need to identify whether the issue is with the valve or elsewhere. The wiring (despite being a hideous mess of colours) does look OK to me (although some assumptions have been made about the stats and valve).
It seems likely that the boiler is doing what it is supposed to be doing but the valve isn't routing the water correctly to the cylinder.
With the wiring as it is and all components working, there's no reason your heating shouldn't work when the HW is off. Power comes from the programmer, out to the room stat, into the valve, out the valve when open to the boiler/pump.
