Hi, I have a problem with my central heating. Basically, even if I put the thermostat up to 30, the heating switches off after around 30 minutes or so. The house is only luke warm at this stage hence I need it on for longer. Any idea what is causing this? I did previously have an issue with air in the system but think this is fixed now - could there be any link to that? I have a regular boiler system with a tank by the way.
Initial thoughts are that the pump is on the way out and needs replacing as the living room radiator only gets warm if I turn all the other radiators off. Even after balancing the living room radiator is still cold and only gets warm when others are completely off. I'll try putting the pump on max tonight and see if that helps.
I read that the pump is supposed to get warm - mine however gets very hot and you can only touch it for half a second.
Many thanks.
Many thanks.
