- Joined
- 25 Apr 2016
- Messages
- 2,633
- Reaction score
- 628
- Country
How are you sharpening the chain? The depth gauges look to be very variable in size. Is the angle of the cutting edge on the cutter correct? - most are 35 degrees.
Finally, as others have said - the saw should be using an Oil tank of chain oil to a tank of fuel; any less and you have a problem. Without the chain and bar in place with the engine running there must be a flow of oil seen into the area of the bar mounting. There may be a hole through the width of the bar fed by the chain oil pump where the oil appears with the bar off.
You say the chain oil flow is adjustable - 'play' with the adjuster with the bar off to find out which give the greatest flow.
