To be honest I think thats a little rude when some one is only trying to help.
I’m just weighing the two pics on the chains in relation to where the oil suply hole is
In the bar are two holes.
The top hole is where the oil feed is supplied for the bar & the lower hole is the position for the adjustment screw to locate into.
I had originally fitted a 52 link chain as at the time i was unable to locate a 53 link chain.
This then made the bar come back slightly.
Now ive managed to locate the 53 link chain i fitted it up & took the photo.
Also did the same with the 52 link chain.
The hole in the bar is blocked when the 52 chain is fitted but aligns correctly when the 53 chain is fitted.
This is the reason why no or next to no oil was on the bar.
My mistake from the start for using the 52 link chain even though it fitted.
