Hi guys.
I decided to change a double socket in my hall from white to a nice metal one and would like to do the whole house over time. I've done a light switch before but first time doing an actual socket, So knowledge is very basic. I have a friend whos an electrician who guided me a little but is quite busy and I feel like I'm pestering him for help so I did most of it on my own. House was built around 35 years ago, not sure if this socket has always been here.
I took out the 3 sets of cables and transfered them over into the new socket.
I had -
1 Yellow and green, 1 black for earth (not sure why, someone suggested they could have just sleaved it wrong?)
2 black for neutral
2 red for live.
My electricain friend asked was the back box earthed, I wasn't sure and had already put it back together so I can't take it apart now but he said it should have a cable running from the earth to the box as well, I don't know if this is something I can do myself or should do? From a google search all I keep finding is if the back box has a lug then its generall fine.
So after some research it seems a lug is one of the screw holes which does NOT move, this is true for my back box, one side is moveable one side is immovable. But he says this is different and I still need to earth the back box?
I don't remember seeing a cable going to the box or anything so I'm pretty paranoid now and unsure if I should use the socket? I know the black wire is a little strange, The socket worked fine before and works fine after.
Any help would be much appreciated.
Thank you!
Images -
https://ibb.co/5sJ80wz
https://ibb.co/5s0YPR0
https://ibb.co/nCLRst8
https://ibb.co/nbbSbxf
https://ibb.co/dJR37yP
I had -
2 black for neutral
2 red for live.
Thank you!
Images -
