I have a ReChargeable Torch with a 6vdc sealed lead acid battery & 12v charger/adapter/smps.
The thing has stopped taking a charge.
The charger/? seems to be working o.k.
The battery is new and will hold a charge when given one.
To me (?!) it looks like something in/on the regulator board in the torch handle has gone.
At the moment I have the battery out & charging it on my sons car batt charger (6V).
I don't mind doing this once in a while, but was wondering if I can cut out the regulator board and feed the battery direct from something like a car batt charger.
1/ Am I right in assuming that I can just take out the board + make an adapter lead to connect charger to input on torch ?
2/ Can I just use a 6vdc charger/adapter/smps (with appropriate aH) and also bypass the board ?
Of course, this isn't life threatening and I know that some of you will think (and say) "it's a cheap piece of tat - throw it away". Obviously you arn't the guys that I'm trying to reach.
I'm now disabled and trying to keep my hands and brain ticking over,,,, so I do like to try fixing things. If all else fails, I will replace it - but in the meantime,,,,,
any help or advice will be appreciated.
thanks for reading
thanks for reading
