You see, coatings are the reason that fluorescent tubes are so energy efficient: light bulbs put out a lot of energy in the IR and UV parts of the spectrum. Tubes (and energy saving bulbs) don't put much out in the IR hence they are quite cool to the touch), and convert UV light into visible light through the phosphorescent coating.
The chosen gas IS responsible for the colour of "neon" tubes, as they are usually clear rather than coated.
Some light is invisible to the eye because it is outside the frequency range of the retina. Just think of it like your ears: most people can hear between 20Hz and 20KHz. Just as you can't hear a whale's mating call (too low frequency) you can't see IR. And just like you can't hear a dog whistle (too high frequency) you can't see UV.
Interestingly, not all animals see in 3 primary colours. Most birds see 4 primary colours, one of these being UV, plus they can detect the polarisation of light. So blackbirds might look pretty colourful to each other!
