I'm Confused (easily done!)
I'm installing a Grant 15/26 vortex oil condensing boiler and within the documention it states that the return temperature must not fall below 40 degC and Ideally will be at 50 degC with a differential temperature of 20 degC, the reason being that the resulting condensate will corrode the heat exchanger. I spoke to the technical dept in Grant and they confirmed this.
Yet when I research Condensing Boilers on the Internet it seems that the whole point of a Condensing boiler is to have a low return temperature to allow it to condensate and without which its efficency will drop. Condensing boilers are supposed to be ideal for systems with a low return temperature (as low as 35 degC). This appears to contradict Grants requirements !!.
I'm fitting the boiler in a 5/6 bedroom and I'm conserned that the return temperture will be too low and I wont be able to maintain an economical and non-corroding system without some sort of indisciminate loop back from the feed.
Can anyone explain this or have any ideas of what can be done to maintain a 20degC differential.
Cheers,
Ady.
Cheers,
Ady.
