Oh absolutely, but that restriction is not a result of restrictions in the (smaller) radiator itself. That was my point to our friend, or at least I think it was - this thread seems to have gone on a bit of a wild goose chase so apologies to the OP for my contribution to that...I thought that a small radiator should have a greater restriction at the lockshield.A smaller radiator restricts the flow no more than a big one.
Hopefully, the OP has gone off to try his boiler's SARA function.this thread seems to have gone on a bit of a wild goose chase so apologies to the OP for my contribution to that...
That's right.My limited understanding is that condensation only begins when then return temperature drops below 55°C. However, I thought it became more effective as the temperatures drop still further.
No.There is much misunderstanding in this thread.
Delta T is the difference between return and flow temperature
It can also mean a time difference - look it up on the NASA website.Delta T is only a term used to denote a temperature difference.
I assume you have more than two rads!Just done the boiler size calculator. According to this my heating requirement is 12.86kW.
My radiator outputs are 571W (1200x450) and 286W (600x450). Not sure what the towel rail would be.
Those rad outputs seems very low. Are they definitely the type without fins on the back?Lol, sorry.
(571x4)+(286x3) = 3142W
Plus a towel rail, so say 3.6kW.
Hmm, kinda low right?
