deleted
Is that meant to be a sensible objection?So you are saying that we must not say anything but "get an electrician", but we must point out things he is doing wrong (and tell him to get an electrician). The two are mutually exclusive.
That's encouragement.Whuich if you bother to read what is written, rather than what you want to have been written, you will see that we agree on that - neither of us have suggested we encourage in any way him doing this work (quite the opposite). But since he appears to have decided to go ahead anyway, we feel it is not unreasonable to attempt to mitigate as best we can the risks.
See aboveBut a) is incompatible with what you wrote earlier :
The ONLY thing we should tell him is to get an electrician. Anything else would be a shamefully irresponsible dereliction of duty.
Trying to help him in any way is encouragement, it is facilitating.Most of the responses have been the same. Only a couple have actually suggested what to use - and I think only after it's become clear that he's going to do it anyway so we may as well try and get him to do it as safely as we can influence.
Go on then - show where I said that was "good".Ah, so now you are doing another U-turn
First you said "get an electrician" is the only advice that should be given, then you U-turned and said it was OK (in fact "good") to try and mitigate things when it's clear he's going ahead anyway, now you've U-turned again to "get an electrician" is the only thing to be said.
